IRremote Library - Deprecated Function Call
Hi All,
I’m using IRremote Library.
This is my code:
#include <IRremote.h>
int RECV_PIN = 7;        // IR LED pin
IRrecv irrecv(RECV_PIN);
decode_results results;
int Q1 = 2;              // Dig Out
int Q2 = 3;              // Dig Out
int Q3 = 4;              // Dig Out
int Q4 = 5;              // Dig Out
int BEEP_PIN = 6;        // Beeper pin
int Code = 0;
  irrecv.enableIRIn();   // Start the receiver
  pinMode(Q1, OUTPUT);   // Setup the H-bridge outputs
  pinMode(Q2, OUTPUT);
  pinMode(Q3, OUTPUT);
  pinMode(Q4, OUTPUT);
  pinMode(BEEP_PIN, OUTPUT);
  digitalWrite(Q1, HIGH);  // Set Motor to stop as initial state
  digitalWrite(Q2, LOW);
  digitalWrite(Q3, HIGH);
  digitalWrite(Q4, LOW);
  digitalWrite(BEEP_PIN, HIGH);  // Beeper on
  delay (500);
  digitalWrite(BEEP_PIN, LOW);  // Beeper off
// MAIN LOOP
  if (irrecv.decode(&results)) {
    //Serial.println(results.value, HEX);
    Code = results.value;
    irrecv.resume(); // Receive the next value
I’ve read through the API documentation and not sure if it hasn’t been updated as yet, but I get this error message and my results all print out as zero.
warning: ‘bool IRrecv::decode(decode_results*)’ is deprecated: You should use decode() without a parameter. [-Wdeprecated-declarations]
Did you try compiling a library example sketch?
It is documented in the README:
Thank you very much - I was browsing through the API documentation and the official website.
I am still however slightly confused on how to use this.
Can I please be provided with a link for further reading or a code snippet.
Thanks
shawn_t:
Thanks
I have checked through the example sketches.
I am unsure as to how to get the HEX values from the decode object. (If it is called an object - I'm not familiar with object orientated programming).
All the example sketches call functions to print various information to the serial monitor on the protocol, timing and HEX code of each button press. I can obviously see the HEX code for each button, but don't know how to obtain and assign it to a variable.
I need to do a switch case statement for volume up and volume down pressed which will control a H-bridge circuit.
It looks to me like you would find that in ‘IRrecv.decodedIRData.decodedRawData’ . The example base doesn’t seem to include anything that doesn’t just print values. This 3.0.0 code base looks like it’s been pushed quite far without clean up. The documentation in the wiki appears to be mostly out of date.
I suggest starting with the basic receive demo and adding that to it. I didn’t have time to dig into this, but it looks like maybe some kind of command decode has been added, or at least will be added. That is in ‘IRrecv.decodedIRData.command’.
Here is where all that stuff “lives”:
struct IRData {
    decode_type_t protocol;     ///< UNKNOWN, NEC, SONY, RC5, ...
    uint16_t address;           ///< Decoded address
    uint16_t command;           ///< Decoded command
#if defined(ENABLE_EXTRA_INFO)
    uint16_t extra;             ///< Used by MagiQuest and for Kaseikyo unknown vendor ID
#endif
    uint8_t numberOfBits; ///< Number of bits received for data (address + command + parity) - to determine protocol length if different length are possible (currently only Sony).
    uint8_t flags;              ///< See definitions above
    uint32_t decodedRawData;    ///< up to 32 bit decoded raw data, formerly used for send functions.
    irparams_struct *rawDataPtr; /// pointer of the raw timing data to be decoded
shawn_t:
Hi shawn_t, did you manage to get a way to assign the code to a variable? I've got the same issue with that library update.
Hi yomhei,
You can use *IrReceiver.decodedIRData.decodedRawData *
I checked and I see that in this object the input data is stored.
You can also verify the hex code received by printing it in your Serial monitor:
Serial.println(IrReceiver.decodedIRData.decodedRawData, HEX);
dragovich:
Hi yomhei,
You can use IrReceiver.decodedIRData.decodedRawData
Thx dragovich. That'll teach me to read the GitHub wiki before to ask, Everything was there.
