IRremote library doesn't work normally
I am trying to build an intelligent alarm that detects when the person is still asleep (and if the person is, it stays on and keeps playing music). It uses a 16 02 LCD screen and a DS3231 clock module. The IRremote library works fine on its own, but when I inserted the LCD library and added the code for the LCD screen, this line >>> IRrecv irrecv(receiver); will get underlined as wrong:
Arduino: 1.8.4 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
exit status 1
'receiver' was not declared in this scope
On its own, the same line and the same code worked and still works.
Here’s the code on its own:
#include <IRremote.h>
int receiver = 2;
decode_results results;
void setup()  {
  Serial.println("Inizio rilevazione");
  irrecv.enableIRIn();
  if (irrecv.decode(&results)) {
    Serial.println(results.value);
    irrecv.resume();
little sidenote: the code was written by me, I did not copy anything.
Code with LCD screen:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int data;
int data2;
int data3;
int data4;
int pos;
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  lcd.begin(16, 2);
  lcd.clear();
    if (pos == 0) {
      if (results.value == 16753245) {
        data = 10;
        Serial.println(data);
      if (results.value == 16738455) {
        data = 0;
      if (results.value == 16724175) {
        data = 1;
      if (results.value == 16718055) {
        data = 2;
      if (results.value == 16743045) {
        data = 3;
      if (results.value == 16716015) {
        data = 4;
      if (results.value == 16726215) {
        data = 5;
      if (results.value == 16734885) {
        data = 6;
      if (results.value == 16728765) {
        data = 7;
      if (results.value == 16730805) {
        data = 8;
      if (results.value == 16732845) {
        data = 9;
      pos = 1;
      irrecv.resume(); // receive the next value
    else if (pos == 1) {
        data = 10;
        Serial.println(data2);
        data = 0;
        data = 1;
        data = 2;
        data = 3;
        data = 4;
        data = 5;
        data = 6;
        data = 7;
        data = 8;
        data = 9;
      pos = 2;
    else if (pos == 2) {
        data = 10;
        Serial.println(data3);
        data = 0;
        data = 1;
        data = 2;
        data = 3;
        data = 4;
        data = 5;
        data = 6;
        data = 7;
        data = 8;
        data = 9;
      pos = 4;
    if (pos == 3) {
        data = 10;
        Serial.println(data4);
        data = 0;
        data = 1;
        data = 2;
        data = 3;
        data = 4;
        data = 5;
        data = 6;
        data = 7;
        data = 8;
        data = 9;
      pos = 0;
  esegui();
void esegui() {
  //empty for now
What could be causing the problem? Is the library broken? It surely has lots of problems…
Thank you
Have you tried to assign it to its number.
int receiver = 2;
The error is correct. In the first sketch, you declare a variable named receiver:
int receiver = 2;
In the second sketch, you don't.
Did you declare the variable before or inside your main function?
