IRremote library problem
Hi everyone,
I just installed IRremote library and when i try the exemple IRsendDemo I get this compiling error IRsendDemo:24: error: ‘class IRsend’ has no member named ‘sendSony’ . I tryed to find a solution but nothing worked. I tryed the library on latest Arduino IDE version and 1.0.6. I get this error with any method call.
The code:
#include <IRremote.h>
#include <IRremoteInt.h>
 * IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
 * An IR LED must be connected to Arduino PWM pin 3.
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
IRsend irsend;
  if (Serial.read() != -1) {
    for (int i = 0; i < 3; i++) {
      irsend.sendSony(0xa90, 12); // Sony TV power code
      delay(40);
Use not
Where did you put the library?
Did you close and restart the (all) IDEs after you imported the library?
Yes i did. I copied the library in "C:\Program Files (x86)\Arduino1\libraries" . Here is installed.
And in C:\Users\avlad\Documents\Arduino\libraries.
The receiving IR example works well. I don't know what`s the problem with the sending class. It's there any other similar library i can try?
Remove it from here.
See: http://arduino.cc/en/guide/libraries
Update:
I used IRLib successfully. On Linux machine i installed in the same way both libraries, same error for IRremote. I will try tomorrow to delete that folder on windows.
