I'm testing out my IR Receiver by using my Air Conditioner Remote. When I press a button such as Power, it just shows the decoded IR data as '0'. Any ideas?
Here is my wiring, sorry for the bad quality. Also, when I fiddle with wires/the board it often makes the receiver go wild, giving random values very fast.
The IR receivers are sensitive to noisy power. A 0 return is a noise trigger, i just have a > 0 gate before i run my button SWITCH statement block.
Its dead easy to use, Vcc, gnd, and signal, but they want solid power. Its not just an IR LED, there's a demodulator in there as well. Try also a piece of red plastic to block out stray light on the sensor.
Sorry for the late reply, I have been busy recently.
Update:
I am receiving codes for both my fan remote and TV remote seemingly well. Can't test them yet since I don't have an IR LED/transmitter available.
The only problem I am now coming across is just the A/C remote returning 0 when it is pressed. It is not a noise trigger because it does print a new received infrared that is 0x0:
WDYM ignore 0s. Everytime I press the POWER toggle button on my A/C remote, Serial prints 0. So it is detecting that I'm pressing something but for some reason it doesn't recognize its data. That's what I'm trying to solve.
The IR module isn't just an IR diode, there's a decoder built in. If the decoder doesn't "decode", there's nothing to return. If it did send something every flash of light would send something. Better to stand silent than to shout continuously wrong things.
to let you know it received SOMETHING and that the decoder isn't dead unresponsive to a direct, strong signal. Imagine your frustration of watching the rx led flicker and nothing ever happens. this way you can tell "broken" for "I don't understand"
yep. no law manufacturers must follow "standard" protocols. Some manufacturers do it intentionally so you have to buy from them. Ever tried to plug a pc device into an Apple?
There is a chance that the remote's modulation frequency is not the same as the receiver's. If your receiver is 38KHz the remote has to be near the same.
