Hello. I'm making a RC car for a school project but I when I try to test the sensor out It shows only zeros. Here is the code.
#include <IRremote.h>
#include <IRremoteInt.h>
const int RECV_PIN = 8;
const int SolMotor1 = 5;
const int SolMotor2 = 6;
const int SolMotorEN = 9;
const int SagMotor1 = 7;
const int SagMotor2 = 8;
const int SagMotorEN = 10;
const int echoPin = 11;
const int trigPin = 12;
int Hiz = 255;
IRrecv irrecv(RECV_PIN);
decode_results results;
#define CH1 0xFFA25D
#define CH 0xFF629D
#define CH2 0xFFE21D
#define PREV 0xFF22DD
#define NEXT 0xFF02FD
#define PLAYPAUSE 0xFFC23D
#define VOL1 0xFFE01F
#define VOL2 0xFFA857
#define EQ 0xFF906F
#define BUTON0 0xFF6897
#define BUTON100 0xFF9867
#define BUTON200 0xFFB04F
#define BUTON1 0xFF30CF
#define BUTON2 0xFF18E7
#define BUTON3 0xFF7A85
#define BUTON4 0xFF10EF
#define BUTON5 0xFF38C7
#define BUTON6 0xFF5AA5
#define BUTON7 0xFF42BD
#define BUTON8 0xFF4AB5
#define BUTON9 0xFF52AD
pinMode(SolMotorEN, OUTPUT);
pinMode(SagMotorEN, OUTPUT);
pinMode(SolMotor1, OUTPUT);
pinMode(SolMotor2, OUTPUT);
pinMode(SagMotor1, OUTPUT);
pinMode(SagMotor2, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(trigPin, OUTPUT);
digitalWrite(SolMotorEN, LOW);
digitalWrite(SagMotorEN, LOW);
digitalWrite(SolMotor1, LOW);
digitalWrite(SagMotor1, LOW);
digitalWrite(SolMotor2, LOW);
digitalWrite(SagMotor2, LOW);
irrecv.enableIRIn();
Serial.println(mesafe());
if (mesafe() > 10)
if (irrecv.decode(&results))
if (Hiz >= 0 && Hiz <= 255 && results.value == VOL1)
Hiz = Hiz - 50;
if (Hiz < 0)
Hiz = 0;
if (Hiz >= 0 && Hiz <= 255 && results.value == VOL2)
Hiz = Hiz + 50;
if (Hiz > 255)
Hiz = 255;
if (results.value == BUTON2)
duzgit();
if (results.value == BUTON8)
gerigit();
if (results.value == BUTON4)
soladon();
if (results.value == BUTON6)
sagadon();
if (results.value == BUTON0)
dur();
irrecv.resume();
dur();
void sol_motor(String dir, int spd)
if ( dir == "ILERI")
digitalWrite(SolMotor1, HIGH);
analogWrite(SolMotorEN, spd);
if ( dir == "GERI")
digitalWrite(SolMotor2, HIGH);
void sag_motor(String dir, int spd)
digitalWrite(SagMotor1, HIGH);
analogWrite(SagMotorEN, spd);
if ( dir == "GERI")
digitalWrite(SagMotor2, HIGH);
void duzgit()
sag_motor("ILERI", Hiz);
sol_motor("ILERI", Hiz);
void sagadon()
sag_motor("GERI", Hiz);
void gerigit()
sol_motor("GERI", Hiz);
void soladon()
void dur()
sag_motor("ILERI", 0);
sol_motor("ILERI", 0);
int mesafe()
long duration;
long int distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration/58,2;
delay(50);
if (distance >= 50)
return 50;
return distance;
