I'm lost when it comes to getting IRremote to sendRaw data.
I've been able to record and send my Samsung remote keys just fine with sendSamsung but when sending UNKNOWN remote info as sendRaw it doesnt work at all -- i am able to record the info though. Using my cell phone the IR led can be seen flashing when using sendSamsung() but there is no flashing when using sendRaw(). I've tried recording my Samsung remote data then sending this raw data back as sendRaw and it still wont work -- i'm unable to turn on my DVD player and there is no IR light being emitted.
Is there some additional data or timing hurdles I must inject for sendRaw to work?
IR code recorded!
Recorded 68 intervals.
Sending recorded IR signal!
I appreciate the assistance. I have the following IR material:
IR Receiver Module(2H24075A, TSOP34838)
IR Emitter Module (2H24073A)
IR Emitter Diode (QED234, SIR-34ST3F)
Regarding the IR Emitter Module and IR Emitter Diode, do both parts accept the exact same data on their DAT lines then produce the same output or must one send particular timed pulses of 5V to the Diode to directly control the IR output whereas the Module expects a stream of integers which itself converts to IR pulses?
Can you explain to me what is the RAW data for UNKNOWN protocols. So far using the updated IRremote library's ReceiveDemo and SendRawDemo havent gotten me any closer to getting sendRaw to work with my Cisco 9865 Set Top Box. I am receiving raw data from my remote but emitting that data back does absolutely nothing when using the emitting Diode or Module. I figure the raw data is grossly incomplete requiring me to dig deeper to eventually compose something useful. Despite what many will think the decoded rawbuf is not a Copy & Send solution but more a debugging tool.
So you can record and send using the Samsung protocol, and it works, but when you try to record the Samsung raw and send that, using the same physical setup and connections, it not only doesn't work, but you don't even see any flashing in your phone camera. Is that right? If so, since all of the physical stuff is the same, the probem must be in software. What version of IRremote.h are you running? Does it have a raw capture/resend example sketch?
