Irsend Transmitter problem
Serial.println(veri, Hex); The value looks correct when I type it, but irsend.sendNEC(veri); irsend is not sending data when I write this. how in HEX format ie irsend.sendNEC(veri, HEX); i can do something like this
#include <IRremote.h>
IRsend irsend;
int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
int buton=5;
int buton1=0;
long veri;
  pinMode(buton, INPUT);
  irrecv.enableIRIn();
  if (irrecv.decode(&results)) {
    veri=results.value;
    Serial.println(results.value, HEX);
    delay(2000);
    irrecv.resume();
  buton1=digitalRead(buton);
  if(buton1==1){
  irsend.sendNEC(veri, 32);
  Serial.println(veri, HEX);
we told you in another post about data formats.
Use
HEX is specific to the print function...
32 is the size of the NEC coding.
āžœ you are still confusing a value and its screen representation and what function parameters are used for...
Hello, the problem was the cable in front of the IR receiver, the data was not going, that's why, thanks
problem solved
