IrSendDemo example code wont compile
Arduino: 1.6.5 (Windows 8), Board: "Arduino Uno"
Build options changed, rebuilding all
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Multiple libraries were found for "IRremote.h"
Used: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
Not used: C:\Users\intel\Documents\Arduino\libraries\Arduino-IRremote-master
Not used: C:\Program Files (x86)\Arduino\libraries\Arduino-IRremote-master
Error compiling.
enabled in File > Preferences.
RobotIRremote
The Robot is not a Uno.
Delate RobotIRremote library, or copy it somewhere else, then it will work. If you delate you will lose this library obviously.
C:\Program Files (x86)\Arduino\libraries\RobotIRremote<-- Delate this or move from libraries
