Is 5.5volts from external regulator to Vin pin enough??
-The voltage regulator is a DC/DC Converter Breakout board (BOB-09370) from www.SparkFun.com
Which utilizes a Lineage Power 12V Pico TLynxTM 6A: Non-Isolated DC-DC Power Module
The output will be 5.5 volts, which will be terminated on the Arduino's Vin and Gnd pins.
According to this spec site, the Vin input should be between 7 to 12 volts:
Will this work? Or is the input too low before going through the internal regulator?
Thanks for your input.
It is too low. You will not get 5V powering your arduino. It might still run but it is not a good idea.
FutureScience:
Will this work?
I'm pretty sure you already answered your own question....
Ideally 7-7.5v
There is also the problem that if Vin is lower then spec then the FET that isolates USB +5vdc from the board will not be turned off so you end up with a low Vcc being wired to your PC's USB +5vdc, which can cause problems when you try to upload a sketch or use the serial monitor.
Thanks for the replies.
That is going to be a problem, I am using this in my car during cold winters.
I have another option; there is a little USB port for a vehicle that regulates 14.4vdc to 5vdc. I need to check the current draw on the port because it will be on 24/7.
Then I can power the Arduino through the USB cable. That will make interfacing easier, but I will loose being able to plug in with a serial monitor while the vehicle is operating.
But why are you limited to the converter you mentioned in your opening post?
There are loads of others, like these at Pololu.
maybe start over and ask what would be the best way to power an Arduino 24/7 from a vehicle that will be in the cold ?
and define cold. we had a guy on here in the Arctic with -50°C or some krazy cold numbers. if you are only in Nebraska with mild cold like -20°F, that might be easier. ?
what power draw ? is it working or sleeping ? RF monitoring ?
The regulators on Pololu look perfect, I can adapt the idea.
So this is in Canada with -30 degree Celsius winters.
The arduino will just power a Chronodot RTC and trigger a relay twice a day. So no much power draw.
