Is a Delay necessary in a loop?
Hello all,
I am using the duemilinove with arduino 0018. I would like to have my loop time to be as fast as possible. However, I noticed that I must have a delay at the end of my loop. I am using timer 1 (ie. pins 3 and 11) as pwm output.
I am using the millis function and storing one loop begin time in an array and the second loop begin time in an array and I calculate delta t. I noticed that dt = 0 when I have no delay in the loop. So I suppose that the delay function somehow affects timer1? But I changed to different pins on different timers and the same problem persists.
I doubt the code will reveal anything but I will place it in here if any of you are curious. Be warned, it is very messy code as of this moment.
Your help is greatly appreciated.
 int anglesensorPin = 1;    //angle sensor input
 int positionsensorPin = 5; //pot input
 int angle_sensor_reading = 0; // ADC value from angle --> 10 bit conversion
 int position_sensor_reading = 0; //same as angle ADC
 float deg = 0; //stores degrees
 float x = 0; //stores
 //float position = 0;
 int motorPin1 = 3; //output to motor lead
 int motorPin2 = 11; //output to motor lead
 //int motorPower = 4; //don't need as motor has its own supply
 float ang_velocity_array[2] = {0,0}; //stores average of thetadot
 float x_velocity_array[2] = {0,0}; //ditto for xdot
 float time_array[2] = {0,0}; //stores time for dt calc
 unsigned long time = 0; //stores total time
 int count = 0; //counting variable for dt,dx,dtheta arrays
 float dtheta;
 float dx;
 float dt;
 float thetadot;
 float xdot;
 float V_hbridge; //LQR voltage
 float percent_duty_cycle; //pwm in percentage from V_hbridge (eg.20% not 0.2)
 int output_to_motor; //outputs LQR voltage to motor
 float a = -17.8837;
 float b = -27.3602;
 float c = 59.3220;
 float d = 16.03;
 const int numReadings = 40; //index for averaging filter
 int readings[numReadings];      // the readings from the analog input
 int index = 0;                  // the index of the current reading
 float xTot = 0;                  // the running total
 float xAv = 0;                // the average
 float thetTot = 0; //ditto for theta
 float thetAv = 0; //ditto for theta
 const int numvelocityReadings = 40;
 int velocity_avg_index = 0; //ditto for velocities
 float xdot_readings[numvelocityReadings];
 float xdotTot = 0;
 float xdotAv = 0;
 float thetadot_readings[numvelocityReadings];
 float thetadotTot = 0;
 float thetadotAv = 0;
 //int test = 7;
   // declare the ledPin as an OUTPUT:
   pinMode(positionsensorPin, INPUT);
   pinMode(anglesensorPin, INPUT);
   pinMode(motorPin1, OUTPUT);
   pinMode(motorPin2, OUTPUT);
   //pinMode(motorPower, OUTPUT);
   //pinMode(test, OUTPUT);
   TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM21) | _BV(WGM20);
   TCCR2B = _BV(CS21); //changes PWM frequency by dividing 16MHz by prescalar value
   //initialize averaging cells to zero once power is on
   for(int thisReading = 0; thisReading < numReadings; thisReading++)
     readings[thisReading] = 0;
     xdot_readings[thisReading] = 0;
   //digitalWrite(test, HIGH);
   time = millis(); //counts time since power on in ms
   time_array[count] = time; //stores the time
   //averaging filter for theta
   thetTot = thetTot - readings[index];
   readings[index] = analogRead(anglesensorPin);
   thetTot = thetTot + readings[index];
   index = index + 1;
   //averaging filter for X
   xTot = xTot - readings[index];
   readings[index] = analogRead(positionsensorPin);
   xTot = xTot + readings[index];
   index = index + 1;
   //resets the cells once up to number of samples
   if(index >= numReadings)
     index = 0;
   //calculates the average
   thetAv = thetTot / numReadings;
   xAv = xTot / numReadings;
   angle_sensor_reading = thetAv; //define the angle sensor reading to the average of theta
   //Serial.println(angle_sensor_reading);
   deg = (angle_sensor_reading * 0.9045 - 73.247 - 180 + 4.51) * (3.14/180); //calibration of theta
   ang_velocity_array[count] = deg; //stores theta for caluclation of dtheta
   //Serial.println(deg);
   position_sensor_reading = xAv; //ditto for xdot
   x = ((position_sensor_reading*0.2294) - 8.0056 - 31.65) / 100; //ditto for xdot
   x_velocity_array[count] = x; //ditto for xdot
   //Serial.println(x);
//if the counting variable dtheta,dx,dt is > 1, takes another measurement of theta,x, t
if(count < 1)
  count++;
  count = 0; //reset counting variable
  //calculates dtheta,dx,dt
  dtheta = (ang_velocity_array[0] - ang_velocity_array[1]);
  dx = (x_velocity_array[0] - x_velocity_array[1]);
  dt = (abs(time_array[0] - time_array[1])) / 1000;
  //calculates thetadot, xdot
  thetadot = (dtheta/dt);
  xdot = (dx/dt);
  //Serial.println(dt);
  //averaging filter for xdot
  xdotTot = xdotTot - xdot_readings[velocity_avg_index];
  xdot_readings[velocity_avg_index] = xdot;
  xdotTot = xdotTot + xdot_readings[velocity_avg_index];
  //averaging filter for thetadot
  thetadotTot = thetadotTot - thetadot_readings[velocity_avg_index];
  thetadot_readings[velocity_avg_index] = xdot;
  thetadotTot = thetadotTot + thetadot_readings[velocity_avg_index];
  //same indexing idea as average for x and theta
  velocity_avg_index = velocity_avg_index + 1;
  //Serial.println(xdot);
  if(velocity_avg_index >= numvelocityReadings)
  //ISR HERE?
  //calculates average for xdot and thetadot
  xdotAv = xdotTot / numvelocityReadings;
  thetadotAv = thetadotTot / numvelocityReadings;
  //Serial.println(xdotAv);
  //LQR equation
  V_hbridge = (a*x_velocity_array[1] + b*xdotAv + c*ang_velocity_array[1] + d*thetadotAv);
  percent_duty_cycle = 11.894 * V_hbridge;//set zero intercept
  output_to_motor = abs(((percent_duty_cycle/100) * 256) + 1);
  Serial.println(V_hbridge);
  //Output to motor lead depending on V_hbridge polarity
  if(V_hbridge < 0)
      //output_to_motor = 1.25*output_to_motor;
      //output_to_motor = output_to_motor + 50;
      analogWrite(motorPin2, output_to_motor);
    //output_to_motor = 2*output_to_motor;
    //output_to_motor = output_to_motor + 25;
    analogWrite(motorPin1, output_to_motor);
  //ISR?
  x_velocity_array[0] = 0;
  x_velocity_array[1] = 0;
  time_array[0] = 0;
  time_array[1] = 0; //was [0]??
//digitalWrite(test, LOW);
//Serial.println(time);
delay(1);
Maybe it's because millis returns an int and your code is so fast that a full millisecond does not pass? Try using micros instead.
edit: oh, sorry, not int, but unsigned long, which is integral too.
Look at where count is used in your code.
It is initially set to 0. Then, it is used as an index into the time_array, ang_velocity_array, and x_velocity_array arrays.
Then, count is incremented to 1, since it was 0, and loop runs again.
Values are stored in the second position of the time_array, ang_velocity_array, and x_velocity_array arrays.
Then, count is set back to 0, and the deltas are computed. On the 2nd pass through loop, you should get proper values.
Then, you initialize the time_array and x_velocity_array arrays, but not the ang_valocity_array array, and loop again.
I think you'd get better results if, when count is 0, you stored the values in the [0] position of the three arrays, and then set count to 1.
When count is 1, store the values in the [1] position, and compute the averages. Then, copy the values in the [1] position to the [0] position, and loop again.
At the very least, you'd computes averages on every pass (except the first), instead of every other pass through loop.
