Is Arduino compatabile with windows10 on 32bit machine?
Hi. Just getting started & getting a compile error. Can I run Arduino on a 32-bit machine w/Windows10? Any advice/experience appreciated.
error message -
Arduino: 1.8.16 (Windows 10), Board: "OLIMEX ESP32-EVB, 80MHz, 115200, Default"
fork/exec C:\Users\ciara\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.1.0/esptool.exe: This version of %1 is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher.
Error compiling for board OLIMEX ESP32-EVB.
you have a problem with esptool.exe from esp32 arduino boards support package, not with arduino
OK. Makes sense. Thank you. It's a good lead.
