Is Arduino UART or USART further is Arduino Half or Full Duplex
HI,
I want to know if Arduino uses UART or USART and please confirm whether Arduino is half duplex or full duplex.
Can I simultaneously transmit and receive data using Tx and Rx pins?
Asking about Arduino UNO. give some highlights of others as well
There are many different "arduino"s
uno
The datasheet for the ATMEGA328P used on an UNO calls the hardware serial interface a USART. The first bullet point in the section on the USART is:
  • Full Duplex Operation (Independent Serial Receive and Transmit Registers)
You mention half duplex. That term usually appears when the user is trying to implement an RS485 serial link (maybe for a Modbus protocol based comms link). With an UNO, the hardware serial port is connected to the on board USB-serial hardware so it is best to avoid using pins 0 and 1, especially if you also want to print out diagnostic information.
If you need a second serial port, then the non hardware option for an UNO is to use a software serial port implementation.
Your other option is to upgrade to a MEGA2560 board with 4 hardware serial ports.
Or using a Leonardo or Micro if the big footprint of a MEGA is a problem or you don't need the additional features/memory. The USART on Leonardo/Micro is independent of the USB connection an can be used freely. It even has HW Flow control, which the 328P processor doesn't have.
