Is Arduino UNO going bad?
has my arduino gone bad, or have I done something wrong in the code ?
These prints where taken without doing any physical changes to the arduino, if you notice pin 10 state is changing between LOW and HIGH without any physical changes or connections !
while the prints where taken pin 10 was not connected to anything.
What could it be ?
An unconnected input is "floating" and its state will be random, just as you observed. To prevent floating we connect the input to a known state. That is where pullup or pulldown resistors come in.
See the digital pin tjutorial.
No surprise there if you do not have a pullup or pulldown resistor connected to the pin to keep it in a known state. It is picking up electrical signals from the environment
Try pinMode(10, INPUT_PULLUP); to turn on the Arduino's built in pullup resistor
Please follow the advice given in the link below when posting code , use code tags and post the code here to make it easier to read and copy for examination
