Hello,
I have an Arduino Nano board that I am working with. I am having some trouble with some very simple code (see below) that works precisely as expected when the input is #2 but works differently when the input is #4. When the input is #2 pressing the button (attached to i/o #2) results in printing "on"...releasing results in printing "off". However when the input is #4 pressing the button (now attached to i/o #4) results in "on" then "off" being printed...releasing the button has the same result...prints "on" then "off".
Here is the code
const int Switch = 4; // pin connected to the push button
int State = 0; // state of the button
int lastState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(Switch, INPUT);
// initialize serial communication:
//int vidState = DebounceInput(videoSwitch, lastVidRead, lastVidDebounce);
State = digitalRead(Switch);
// if the state of the On\Off button has changed
if (State != lastState)
// if the on/off button was pressed...
if (State == HIGH)
Serial.println("On");
Serial.println("Off");
lastState = State;
Is there something special about pin 4? Does it somehow function differently? Do I need to do something different to set it up?
Thanks in advance for any help with this. Steve
