I tried defining a variable called 'direction' but the IDE turned it orange, indicating a keyword. I can't find anything in referrence about it. I'm curious as to what it does and how to use it.
I've renamed the variable as 'compass'.
All that means is that some library developer decided that direction was a keyword. If you are not using that library, or not using that function/method/whatever, then the color is useless/incorrect in your context.
I'd put it back, if direction makes more sense.
Sometimes to avoid conflict with these library or system parameters, I would define my_direction or robot_direction etc. Also as a library developer, I would define things like phi_prompt_direction instead of direction to avoid conflict with another developer.
Thanks for your replies, guys. I'll probably go with 'my_direction', or something similar, as this is more meaningful. It's a boolean that holds 0 for forward and 1 for reverse.
Happy to help. More people program well = less work for all the rest of us
