Is E (134794) wifi:sta is connecting normal on serial monitor after disconnect to connect again?
hello i am working on esp32 wifi with one push button to turn off and turn on and i finished working on it but i have a little problem when i reconnect. when program starts, wifi turns on without pressing the push button then on the serial monitor appears Connected: 192.168.100.91 after that i click again the push button then the wifi is in a off condition Disconnected. My IP address is: 0.0.0.0 and when I turn it back on, here the root of the problem appears on the serial monitor E (134794) wifi:sta is connecting and its back to connected again. is that normal? or errors? If it's an error, what code should I use, please help, thanks in advance
#include <WiFi.h>
#include <OneButton.h>
#include <ExBreaker.h>
OneButton button(13,true);
int i=0;
int statuz = WL_IDLE_STATUS;
void doubleClick(){
  state =! state;
    button.attachDoubleClick(doubleClick);
void loop(){
  // keep watching the push button:
  button.tick();
  // You can implement other code in here or just wait a while
  delay(10);
     if( state== LOW){
    WiFi.begin();
   Serial.print("Connected: ");
   }else if (state == 1){
    Disconnect();
issuing a WiFi.disconnect(); would erase the known ssid/password and prevent automatic connection the next time you boot
do you know code besides disconnect to turn off wifi?
If you want no radio, to turn Wi-Fi and Bluetooth off try
WiFi.mode(WIFI_OFF);
btStop();
i just change WiFi.disconnect(); to WiFi.mode(WIFI_OFF); but still show E (134794) wifi:sta is connecting on serial monitor.
Post the code
main code
#include <WiFi.h>
int i=0;
int wstatus = WiFi.status();
void doubleClick(){
  state =! state;
    Connect();
void loop(){
  button.tick();
  delay(10);
    if( state== 0){
     WiFi.begin();
   }if (state == 1){
    Disconnect();
code void disconnect
void Disconnect(){
//  WiFi.disconnect(ssid, password);
  Serial.print(F("Disconnected. My IP address is: "));
code void connect
void Connect(){
//  WiFi.disconnect(false);
  WiFi.begin(ssid, password);
well, you call connect() in the setup(), why would you be surprised that the connexion is made?
Side notes:
Don't post snippets (Snippets R Us!)
➜ where is state declared?
➜ please make an habit to indent the code in the IDE before copying, that's done by pressing ctrlT on a PC or cmdT on a Mac)
this looks nicer and easier to read, don't you think?
  button.tick();
  delay(10);
  if ( state == 0) {
    WiFi.begin();
  if (state == 1) {
    Disconnect();
PS: state is likely a boolean, so you could do
if (state) {
i change the code
#include <WiFi.h>
OneButton button(13, true);
int i = 0;
void doubleClick() {
  state = ! state;
  Connect();
  button.tick();
  delay(10);
  if ( state == 0) {
    WiFi.begin();
    Disconnect();
still not fix the problem
serial monitor
15:42:25.334 -> E (175026) wifi:sta is connecting, return error
15:42:25.334 -> 0.0.0.0
state declared on library ExBreaker.h if i combine all just like this
#include <WiFi.h>
const char *ssid = "Get";
const char *password = "12345678";
int state = 0;
int i = 0;
  state = ! state;
  Connect();
  button.tick();
  delay(10);
  if ( state == 0) {
    WiFi.begin();
    Disconnect();
sorry for being dumb i dont know waht snippets is because im new here i hope you all understand
You probably just have to
This is a part of an answer, just like your code is only a part of the problem description.
Not so useful, don't you think?
