Is Ethershield actually live
Is there a function to check whether the Ethershield is actually connected to a network ? I'm trying to make sure that a fallback (offline, no time check) mode is activated. Currently, I assume that if I can't get a time signal from NIST then I don't have a network, but that only means that I don't have internet. I might still have a standalone network live. I'm not using DHCP, so the return code from begin() would not help.
But, you are using Ethernet.begin(), aren't you?
When I had a need to do that (to verify just LAN connectivity, not internet), I did a connect to the default GW address port 80 that I used in the ethernet begin. This is my broadband router's web page, most listen on port 80 on the lan and I read the first line just to make sure I got some kind of http reply.
EthernetClient client;
    if (client.connect(router_ip, 80))
// connection is up and running
Neat ideas guys, thanks and definitely will meet needs. Not perfect because in theory the LAN doesn't need a router or even a DHCP server to be a LAN, but in practice will handle the case where the internet (cable) has gone away, which it occasionally does.
