Hello
Is Google Firebase still working
or is there a SSL issue.
I try to connect with an ESP8266 to a Firebase Project but without success
The Datas are available via Browser. I read that this is maybe an SSL Problem.
Any Clue
Hello
Any Clue
Yes.
There were several SSL issues, that's why TLS is used nowadays.
Don't you think it might help if we can see the code that doesn't work? And a slightly more detailed description of "without success" is usually helpful too.
It would be wise to share that knowledge with us. Where is the link to that reading?
This morning I was doing the same sketch with the ESP32 and I did not have any Problem, so it's a Problem with
the ESP8266.
I figured out that there is a Problem with the fingerprint Check this out
In my case it did not help to update the files.
That's not a problem of Google or it's firebase but of the Arduino library programmer. As you didn't post your code and also didn't link to the library you're using, we cannot help.
