I am installing about 120+ Arduino Yuns for a study(not for a commercial purpose). I am having someone install the required tools. Since I am charged by the hour, I am trying to save time on the installation process.
The Yuns that I bought have the following version:
=Fri Apr 11 04:46:31 CEST 2014
From the change log, I see that the installed version contains fixes to heart bleed problem and other major updates. I do not see any other problems that would be fixed by upgrading the Yun to 1.5.3.
My application also seems to be running without an OS update. Would I be missing a major feature update if I do not update my Yun's linux image to 1.5.3?
@yamanoorsai,
it is not absolutely required. However, there has been some bug fixes that are useful, such as the bridge library, time, network fixes and storage. However, I should be clear. There is a YunOS update, the linux portion, and the IDE upgrade. You should upgrade your YunOS. This can be automated. The IDE cannot.
Release Notes for the IDE
FWIW: I'm sure someone will be by later with more information.
uci add fstab mount
uci set fstab.@mount[0].target=/
uci set fstab.@mount[0].device=/dev/sda1
uci set fstab.@mount[0].fstype=ext4
uci set fstab.@mount[0].enabled=1
uci set fstab.@mount[0].enabled_fsck=0
uci set fstab.@mount[0].options=rw,sync,noatime,nodiratime
uci commit
/bin/ash bootsd.sh
Step 3a. Clone Yun OS fro first Yun's SD at Linux Box by dd Command
Step 3b. Far more scaleable solution 1 to 63 SD/microSD Card Duplicator Memory Flash Drive Copier
In 10 mins upgrade 126 Yuns., now you could charge it by minutes!
Thanks. Steps 1 and 2 helped me out. Since I am using a microSD card, I am wondering if I should make my filesystem read only. In my application, I am writing data to the RAM and uploading it. Would there be microSD card failure from read cycles?
yamanoorsai_15:
Not with microSD , but could be with internal flash and Image ( firmware ) Generator. SquashFS is read only and reduced size
sonnyyu:
Plan B:
Image ( firmware ) Generator:
Embedding packages directly into the SquashFS to reduce space requirements on the target
Preconfigure images by embedding packages and configuration files directly into SquashFS, and save manpower when flashing many devices
Building minimal images. for example without the web interface
Learning
Yun based on AR9331 , maximum flash size is 16MB. The newer CPU could support 128MB or 256MB flash memory. Use Image Generator will save a lot of manpower when flashing many devices. And save the cost and space with out Micro SD or USB flash driver.
