is it any serious difference between if else and else if
if else () {
else if () {
Yes
Read:
https://www.arduino.cc/en/Reference/Else
Using 'else if' is similar to switch/case
I see no real difference, both snippets will not compile, so they are functional identical.
No, else if () won't compile as there's no if() before the else.
if else () {} won't compile and even if it did, won't do what you expect either. The code in the braces {} will always be executed because the expression in brackets () forms the body of the else clause.
thanks
The only two valid forms for an if-statement are:
 if (EXPRESSION) STATEMENT
or
  if (EXPRESSION) STATEMENT else STATEMENT
Your "if else () S{}" won't compile because there is no '(' after the 'if'.
Your "else if () {}" won't compile on its own because the 'else' does not follow " if (EXPRESSION) STATEMENT" and because the '()' after your 'if' do not contain an EXPRESSION.
To elaborate a little on JohnWasser's reply #5
else if is nothing more than
if (firstCondition == true)
  if (secondCondition == true)
    if (thirdCondition == true)
Note that (in my attempt to make it clear) I left out the {} around the elses; not something I would do under normal circumstances.
OP: it's pretty obvious that you asked this question without even typing the code into the IDE and seeing if it compiles.
As always when someone asks a really, really basic question about C++ syntax, I suggest you google "C++ tutorial" and do the first few chapters of any of the seveal free online tutorials on the web. Personally, I learned C out of the blue book in '85 using 'ed' on a teletype machine to edit my code without having to go to forums to ask people questions like this.
Grrrr.
PaulMurrayCbr:
Grrrr.
I was a little later; wrote my first serious C program (for my thesis on digital image processing) in 1988 using vi as the editor :slight_smile: Thank goodness I had a mentor that was a quite well versed in C.
As others have pointed out
if else ()
is meaningless
However, compare these two and note their difference
if (this is true)  //single condition
    do this if the condition is true
    always do this
and
if (this is true)  //first condition
    do this if the first condition is true
else if (this is true) //second condition
    do this if the second condition is true
Note the implied
    do nothing
at the end of the second example
NOTE ********************************
See subsequent posts for corrections to this one
UKHeliBob:
   always do this
Don't you mean:
   // do this, since the condition is true
   // don't do this, since the the condition is true
Don't you mean:
Whoops on my part.
Thanks for spotting and pointing that out.
Rather than cause confusion I will leave my original (wrong) post in place.
