wima75
July 10, 2020, 6:40pm
1
Hi
This works:
char filename[] = "20000101.TXT";
sprintf(filename, "%04u%02u%02u.TXT", gps.date.year(), gps.date.month(), gps.date.day());
openFile(filename);
void openFile(char* name) {
dataFile = SD.open(name, FILE_WRITE);
But when I change the first line to
char filename[12];
it does not work. I think the documentation says, that I have not to initialize the array with values.
Whats going wrong here?
The 12 in
char filename[12];
The string "20000101.TXT" has 12 visible characters and an invisible (to you) terminating zero that denotes the end of the string
Try
char filename[13];
or better still leave out the number as in your first example and let the compiler work it out for you
Robin2
July 10, 2020, 6:47pm
3
wima75:
char filename[12];
it does not work.
I suspect there is a lot of stuff you have omitted to tell us. If the array filename[] has no data in it I can't imagine how you think openFile(filename); could possibly work.
Please post the complete program that does not work so we can see exactly what you have tried.
I wonder if the problem is that you have not added a terminating NULL character to the text that you put into the array.
...R
wima75
July 10, 2020, 6:51pm
4
UKHeliBob:
Ou yeah, thank you for this fast reply.
He fills the array, so to speak, with sprintf(…), which certainly places a terminating null character.
Unfortunately after the 12 characters he's allowed as @UKHB points out.
a7\0
