Is it necessary to program Uno before using as controller for MAME arcade game?
I'm considering using an Arduino Uno board with a rotary encoder to use for MAME arcade games. Is it necessary to program these boards prior to being used for that purpose? Thanks in advance for any help. I'm not a programmer and just want to know what to expect if I get one of these boards.
Moved your topic to it's current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
The simple answer is yes, the board needs to be programmed for whatever task you want it to perform.
There are varying degrees of ‘more complex’, but a starting point you need to decide is whether 200 hours of your single-minded dedicated time is worth more or less than buying a completed gadget.
USMC0352:
I had to look up 'MAME arcade game' as I had no clue what this meant. My impression, from a quick look at Google results, is that programming an Arduino, or indeed any kind of micro-controller, for this purpose would very much be an advanced project. Consider how much programming knowledge you already have and how much time you want to spend leaning.
PerryBebbington:
I think that was detailed in the OP, and conservatively elucidated by lastchancename. :astonished:
My impression was that he was planning to run MAME itself on a proper computer (which is what he should be doing) - but wants to make a custom controller with a rotary encoder. And this would connect to the computer running MAME through USB.
You don't want to use an Uno for this - you want something that has native USB and can be programmed to act like a keyboard/mouse/joystick. A leonardo or - probably better due to size - a micro/pro micro is a great choice for this.
You will need to write the code that reads the rotary encoder and uses the Keyboard or Joystick libraries to act like a USB keyboard or joystick (as your needs dictate). I have actually considered doing something like this myself - not with MAME specifically, but for playing Tempest (both the windows arcade version, and the new one) with that wheel. I think the software part is easy, but making a satisfying wheel is non-trivial from a fabrication perspective, since it needs to have some weight to it while spinning freely, in order to feel right. And in any case I put a bunch of equipment in front of my big monitor, so I couldn't use this if I made it anyway.
