Is it ok to declare an int i; then later i++?
i’m trying to figure out how to walk through the memory of an arduino to find fragmentation.
I’ve come across a problem that i’ve never seen before and wanted to ask why it is happening.
This is my code
struct __freelist
    size_t size;
    struct __freelist *next;
extern struct   __freelist *__flp;
extern uint16_t __heap_start;
extern char *__brkval;
extern char     *__malloc_heap_start;
extern char     *__malloc_heap_end;
extern size_t   __malloc_margin;
extern uint16_t __data_start;
extern uint16_t __data_end;
extern uint16_t __bss_start;
extern uint16_t __bss_end;
int *par[10];
// setup for later frag on purpose
int seed = analogRead(A0) + analogRead(A3) + analogRead(A2);
  seed ^= (int)micros();
  randomSeed(seed);
  Serial.println(F("allocate 10 chunks\n"));
  for (int i = 0; i < 10; i++)
    int mSize = random(1, 40) * sizeof(int);
    par[i] = (int*) malloc(mSize); // all different sizes
    *par[i] = 0;
  Serial.println(F("free 3 pointers")); // frag the memory
  free(par[3]);
  free(par[5]);
  free(par[7]);
  par[3] = (int*) malloc(10);
  Serial.println(F("done"));
  CountFrag();
void loop() {}
void CountFrag()
  __freelist *fp;
  int i; // if you change to int i = 0; without uncomment the line below it will say two when printed instead of 157.. but it should say three
  //Serial.print(F("starting i is ")); Serial.println(i); //if you uncomment this it works fine.
  for(fp=__flp;fp;fp=fp->next)
  i++;
  Serial.print(F("i is "));Serial.println(i);
The problem is when
is commented out the serial monitor says
allocate 10 chunks
free 3 pointers
done
i is 155
i is not 155, it should be 3. If you include the
in the sketch the serial monitor will say
allocate 10 chunks
free 3 pointers
done
starting i is 0
i is 3
which is correct. If you change int i; to int i=0 the serial monitor will say
allocate 10 chunks
free 3 pointers
done
i is 2
I want to know what is going on? Is this a overflow? Was the sketch before this one was loaded still in the arduino so it thinks i is the value of the old sketch? Do you have to declare the value of an int when you assign it in the sketch before you use ++?
I don't understand why you think that i in your comment should be three.
i is a local variable. It is assigned to a memory location that contains some junk from the last time that memory location was used. It is a poor programming practice to not initialize ALL local variables.
 i++;
Increment the junk that was there... Not too useful.
which is correct.
No, it isn't.
After you allocate 10 blocks, free 3, and allocate a block that reuses a freed block, the free list length is 2.
No, it isn't.
The only part I changed is blow
void CountFrag() { __freelist *fp; Serial.println(); int i=0; // initialize i to 0 for good programming practice Serial.print(F("starting i is ")); Serial.println(i);
for(fp=__flp;fp;fp=fp->next) i++; Serial.print(F("i is "));Serial.println(i); }
the serial monitor
allocate 10 chunks
free 3 pointers done
starting i is 0 i is 3
why does it still say 3?
Also, I understand this
looks for the next available space in the program that isn't being used. Is it possible to do something similar where it looks for the next used space in the program so that It can tell you then length of each used space?
Allocating random size blocks, freeing 3 of them, and then allocating a fixed length block may, or may not, result in a freed block being reused.
