Is it possible to change this variable?
Hello everyone. I'm wondering if is it possible to do this:
I'm using the control surface library, and I would like to use a counter and put a variable inside the class "Button", so I could press a button and change the value of this variable.
If I use the serial monitor I see that the variable "CC1" actually changes, but when I check this in a midi software, nothing happens, is always sending the first value 0
Thanks!
#include <Control_Surface.h>
HairlessMIDI_Interface midi;
const int buttonPin = 0;
int buttonState = 0;
int prestate = 0;
int CC1 = 0;
int counter(){
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH && prestate == 0) {
    CC1++;
    prestate = 1;
  } else if(buttonState == LOW) {
    prestate = 0;
CCButtonLatched ComandosCC[] = {
  {2, {CC1, CHANNEL_1}},
  pinMode(buttonPin, INPUT);
  Control_Surface.begin();
  counter();
  Control_Surface.loop();
You don't say which Arduino board you are using, but is that the Serial Rx pin that you have the button attached to ?
Does the MIDI interface use a serial interface and if so, which one ?
As far as I can see you do not have a class named "Button" but I am not familiar with the libraries that you are using
