Is it possible to delay a digital signal?
Hi all,
I'm wondering if it is possible with an electronic circuit to delay a digital signal with a variable amount of time. In math: y(t)=x(t-T), where x(t) is input signal, y(t) is output signal and T is variable delaytime.
The signal I want to delay is a squarewave at approximately 2 kHz, and the delay is a couple of degrees so approximately 15us.
The output signal y(t) is sent to trigger an interrupt on a microcontroller so it can't be to different from the input x(t)
Thanks!
Yes, but at 15uS it will need some tight coding I think if you do it with a CPU. A simple RC circuit can do this as well.
Does it have to be a variable delay?
Why is this?
What exactly is the job that needs doing?
Rob
time constant =RC
We used to be able to buy ICs that had that functionality as one little blue module.
These are similar:
http://datasheets.maximintegrated.com/en/ds/DS1135.pdf
Other delays are available http://www.digikey.com/product-search/en?pv420=2&FV=fff40027%2Cfff800e0&k=delay+line&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
Unless you start stacking these up in series, they are just a fraction of 15uS th.
15uS is 240 clock cycles. delayMicroseconds is supposed to be good from 3-4uS and up, so 13-14-15 ought to be possible.
2KHz is 500uS, so maybe this might work:
void loop(){
  while{ (PIND & 0b00000100) == 0){  // hold until PORTD-2 goes high
  delayMicroseconds (8);
  PORTD = PORTD | 0b00000100; // set the delayed output
  while{ (PIND & 0b00000100) > 0){  // hold until PORTD-2 goes low
  PORTD = PORTD & 0b11111011; // clear the delayed output
15 uS. , why ?
Does it need to be continuously variable from 0 to 15 us ? Under software control ?
Thank you for your replies.
I have been thinking a lot about this and I found that probably the best solution for my problem is to do it in software. So I just ordered a DUE. Excited to start experimenting with it!
