Hello,
i am reading the datasheet of at mega and in the section of the timer 1 i saw this formula:
so i supposed that is possible to generate 16mhz output using the fast PWM mode.
but i couldn't do it, the only thing i did was to use the CTC mode to generate 8MHZ.
so i wan't to know if the 16mhz is possible.
thanks
obs: the image is uploaded because i couldn´t embbed it here , don't know why.
westfw
May 20, 2018, 11:12pm
2
Datasheet says ("Fast PWM" section of Timer2 description):
The waveform generated will have a maximum frequency of foc2 = fclkI/O / 2 when OCR2A is set to zero.
I’m talking about the timer 1, check the section 16.9.3
There it says
” The PWM frequency for the output can be calculated by the following equation:
fOCnxPWM = fclk_I/O / (N * (1 +Top))
it may be worth considering an Arduino Due
Timer1 works essentially the same. Immediately below the formula you posted, it goes on to say:
The waveform generated will have a maximum frequency of fOC1A = fclk_I/O/2 when OCR1A is set to zero (0x0000).
6v6gt
May 21, 2018, 7:59am
6
If you want simply a 16MHz output from a 16MHz clocked AVR you can use the fuse CKOUT and get the output on PORTB.
The description is here .
