is it possible to get signal from lcd thermometer to arduino?
is it possible to get signal from cheap thermocouple lcd thermometer to arduino?
like this...? or something else...?
http://www.ebay.com/itm/TM-902C-K-Type-Digital-LCD-Thermometer-Thermodetector-Meter-Thermocouple-Probe/310662903501?_trksid=p2047675.m2109&_trkparms=aid%3D555003%26algo%3DPW.CAT%26ao%3D1%26asc%3D142%26meid%3D7995859124281857479%26pid%3D100010%26prg%3D1076%26rk%3D3%26sd%3D261147835861%26
It is not possible unless TM-902C has ttl/uart interface, and it does not.
I think one solution is use K-Thermocouple to-Digital Converter, then feed into Arduino.
sonnyyu:
tsachi:
I do belive i'll have to use a chip to control it.
I was looking at ebay and found this one http://www.ebay.com/itm/250814950389
Which is actually this http://www.adafruit.com/datasheets/MAX6675.pdf
What do you think? will it work?
MAX6675 is K-Thermocouple to-Digital Converter (0°C to +1024°C)
Yours is Filled Nylon Range -29 to 220°C, as long as you do not care -29 to 0°C range. It will be fine.
Use MAX31855 if u need support negative temperature.
MAX31855 : -200 °C to +700 °C
Probably you have found the solution since 2013 but check this one out - WiFi Oven Thermometer – Bart Slinger
