Is it possible to know why Arduino rebooted?
I'm trying to debug a very weird issue and it will be great to know why board has rebooted.
Somehow my board is rebooting after the values on analog ports changes.
Your question doesn't seem to be associated with programming. Yet you posted in the programming forum..
How are we supposed to help you if we don't know what your project is or what you have hooked up to the Arduino?
Since your question is so vague, I will give a vague answer; the most common reason why the Arduino restarts is you're pulling too much current.
codlink:
Also, the arduino could reboot if you connect the 5v to ground with no resistor.
It's not likely, but you could have connected the reset pin to ground, which also resets the board.
Shouldn't this be in electronics?
Or, you could be running out of memory. Do you use a lot of strings?
Or, the watchdog reset might be firing.
The way I would debug such a thing would be to insert debug Serial.print() statements in the code. Then you would know what was the last thing that happened before it rebooted, and you could print whatever variables or pin states or voltages you thought might be relevant.
TanHadron:
I agree, when free SRAM drops too low, stack overflow causes unexpected behavior but also board restarts
