Is it possible to pass variables to delayMicroseconds()?
Does anybody know of any way to pass a variable to delayMicroseconds?
I need to be able to pass a dozen or so changing variables: from, say, 10µs to 15000µs.
Can you do that in a subroutine or something?
Thanks!
Ian
Yes.
Google tells me that you can.
delayMicroseconds()
Description
Pauses the program for the amount of time (in microseconds) specified as parameter. There are a thousand microseconds in a millisecond, and a million microseconds in a second.
Currently, the largest value that will produce an accurate delay is 16383. This could change in future Arduino releases. For delays longer than a few thousand microseconds, you should use delay() instead.
Syntax
delayMicroseconds(us)
Parameters
us: the number of microseconds to pause (unsigned int)
Returns
None
But VinceHerman, you can only put a number in there (between 4 and 16k or so): not a variable. And DVDDoug… can you show me how to do it, if it really is 'yes'? I can't make anything work.
Try this
unsigned long numberOfMicros = 1000000UL; // this is intended to be 1 million in case I got the 0s wrong
delayMicroseconds(numberOfMicros);
...R
I think it is time for you to show the code that you say does not work.
Doh! Sorry, and thanks, guys. Trying to build a simple module to show you why it doesn't work… and IT WORKS!
That is one of the reasons we ask for code!
