I am new at this so bare with me.
Trying to print to monitor (Serial.println) a mix of text and an integer.
Is it possible.
I know it is possible in a clean C with println("text text &d", int); but it fails.
Using a nano.
thanks
Peter
Is it possible.
Using a nano.
thanks
Peter
Is it possible.
Yes
int anInt = 123;
Serial.print("Number ");
Serial.print(anInt);
Serial.println(" on the screen");
Or use the sprintf() sledgehammer
char buffer[30];
int anInt = 123;
sprintf(buffer, "Number %d on the screen", anInt);
Serial.println(buffer);
Thanks
I have tried the first solution but the result in my mac is the printed in three lines.
Will try your other solution now.
great forum
Peter
Yes the second solution worked perfectly.
thanks
Peter
@PICT - nothing to do with your Mac, I'm 99,99% sure you ended up with 3 lines because you used print[color=red]ln[/color]
instead of print
. The [color=red]ln[/color]
piece in the method call means print the text followed by a carriage return character (ASCII 13, or '\r') and a newline character (ASCII 10, or '\n').
I see.
Yes I used Serial.println after watching a lot of tutorials where they only used that command when printing to screen..
But that is very useful information.
thanks a lot
Peter
pict:
Yes the second solution worked perfectly.thanks
Peter
Be aware that it uses a lot more memory than the first one.
Even better use
Serial.print(F("Number "));
Serial.println(F(" on the screen"));
UKHeliBob:
Even better useSerial.print(F("Number "));
Yes I tried it and it used less memory.
Thanks all of you
Peter
