I have a DHT22 and a DS3231 and I am wanting to print the output from both modules into a HTML local host website instead of the Serial Monitor. How would I do so?
We seem to be missing a whole lot of information.
What Arduino? Does it have wifi?
I am using the Elegoo mega 2560. I also have a Raspberry Pi 0 wh if that can be used. The Raspberry Pi has wifi.
Build a web server and put the data on the web page. Probably easiest to use an esp8266.
What have you got now? Any sketch to run the sensors, at least?
I have the code thats printing the date and time, temperature, and humidity. I want to print it to a local host website instead of the Arduino IDE.
Ok thank you, I'll buy one. Do you know a good tutorial that I can use?
I wrote up a project I built. It is more then you need, but can give you an idea of what to do. I used a DS18B20 as the temperature sensor. Replace that code with the equivalent code for the DHT22.
I record the RTC temperature just to get an idea of how accurate it is. You may want to skip that part. It is speced to be less accurate than a dedicated temperature sensor. I have found that it tracks very close.
you can print to the (web)client very similar like to the Serial Monitor. I assume you find a lot of tutorials if you do some Reserach in the internet
