waski:
So, just change pin number from 13 to whatever you want!
Look at Nick Gammon's example :
// Which pins are connected to which LED
const byte greenLED = 12; // pin number 12
const byte redLED = 13; // pin number 13
// Time periods of blinks in milliseconds (1000 to a second).
const unsigned long greenLEDinterval = 500;
const unsigned long redLEDinterval = 1000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long greenLEDtimer;
unsigned long redLEDtimer;
void setup ()
pinMode (greenLED, OUTPUT);
pinMode (redLED, OUTPUT);
greenLEDtimer = millis ();
redLEDtimer = millis ();
} // end of setup
void toggleGreenLED ()
if (digitalRead (greenLED) == LOW)
digitalWrite (greenLED, HIGH);
digitalWrite (greenLED, LOW);
// remember when we toggled it
} // end of toggleGreenLED
void toggleRedLED ()
if (digitalRead (redLED) == LOW)
digitalWrite (redLED, HIGH);
digitalWrite (redLED, LOW);
} // end of toggleRedLED
void loop ()
// Handling the blink of one LED.
if ( (millis () - greenLEDtimer) >= greenLEDinterval)
toggleGreenLED ();
// The other LED is controlled the same way. Repeat for more LEDs
if ( (millis () - redLEDtimer) >= redLEDinterval)
toggleRedLED ();
/* Other code that needs to execute goes here.
It will be called many thousand times per second because the above code
does not wait for the LED blink interval to finish. */
} // end of loop
I have an LED with an anode and a cathode. How do I fit it in a single pin?
