Is it possible to program dc motor for multi functions
Hi i woundering if i can preprogram dc motor to run for example 1:
Motor a run 60%speed for 5 min then in 80 % next 5 min and so on.....?
Example 2:
Motor a run 60% for 5 min motor b run 50% for 5 min at the same time?
With just 1 button (start) stop
Thx alot
Yes, that's possible.
(Is this my cue to deliver the whole project on a silver platter?)
If the actual speed of the motor is your concern, then you need a method to monitor the speed, then you can write a program to control the speed. All changes if you have a load on the motor, meaning the motor has work to do.
Wow thx for the fast replay
To be more clear
I plan to build a drone simple one the no need for transmitter and reciver
What i think about is to give each motor specefic speed and time and simply make kind of robotic drone that i fo not need to control it all the time
As a biggener how i should stat to learn this topic to come to this level?
Any advices
More info plz?
That's a lot different matter.
Howbeit, the idea is unsound.
Exactly
The idea is close to mission planner without the use of map or gps :sweat_smile::muscle:
Research on flying drones should have shown you that the motors are AC, three phase, and driven by electronic speed control circuits. Those circuits are controlled by your Arduino.
