Is it possible to return text from the Serial monitor to a String?
Hey, i am wondering if it is possible to return something written in the serial monitor back as a string.
I am using this code with a teensy 3.5 and a RFM96 radio module:
#include <Cansat_RFM96.h>
#define USE_SD 0
Cansat_RFM96 rfm96(433500, USE_SD);
unsigned long time_counter=0;
  while(!Serial);
  Serial.println("Starting setup");
  if (!rfm96.init()) {
    Serial.println("Init of radio failed, stopping");
    while(1);
  Serial.println("Found RFM96 radio, and it is working as expected");
  rfm96.setTxPower(5); // +5 dBm, approx 3 mW, which is quite low
  Serial.println("End of setup");
  uint8_t read_value;
  // We check if there it something in the buffer
  while (rfm96.available()) {
    // We keep track of the time since we last received something,
    // so the user can get feedback if the radio does not receive
    // something
    time_counter = millis();
    // Read it into a variable. Here we could just directly use:
    // Serial.write(rfm96.read());
    read_value = rfm96.read();
    // Write it to file. We do not use Serial.print, because the
    // conversion to readable ASCII has already been done when
    // we send it
    Serial.write(read_value);
  if (millis()-time_counter > 5000) {
    Serial.println("We have not received anything in 5 seconds");
The tensy card is receiving a message with the RFM96 module, and translate it with Serial.write(read_value). So i was therefore wondering if i could get back what is written into the serial monitor as a string.
No, it isn't.
But, ask yourself, "who sent the string there in the first place?"
Serial.write() does not turn its data into a string. That is the job of Serial.print().
If you want to do it in your code, use itoa() or sprintf()
