Is it possible to run multiple buzzers and servos together at once?
Hello everyone, I have been trying to make something similar to this [OMFG] - Hello, 450kV Tesla Coil & Robot Orchestra cover [1,000 sub special] - YouTube but not as complex but I can't even come close. No matter what I try, I always get some sort of error message or the circuit just doesn't work. Would it be possible to run many different servos and buzzers together? I am just getting started with this Arduino so it may be a stupid question, but if you know please help. Thanks :slight_smile:
Please post YOUR code and the complete error messages. There should be no problem running multiple servos and buzzers, within limits of the servo library and available pins.
Yes, within some limits
What have you already tried ?
This is my code for attempting to run two buzzers at once:
#include <Tone.h>
int notes = 20;
int melody1 = {
NOTE_A5, NOTE_A5, NOTE_B5, NOTE_C6, NOTE_E6,
NOTE_F6, NOTE_F6, NOTE_F6, NOTE_E6, NOTE_D6, NOTE_E6,
NOTE_C6, NOTE_C6, NOTE_D6, NOTE_E6,
NOTE_G6, NOTE_G6, NOTE_E6, NOTE_G6, NOTE_E6
int mel1Durations = {
800, 200, 200, 200, 200,
400, 400, 200, 200, 200, 200,
800, 200, 200, 400,
400, 200, 200, 400, 400
int harmony1 = {
NOTE_E5,NOTE_E5,NOTE_E5,NOTE_E5,
NOTE_F5,NOTE_F5,NOTE_F5,NOTE_F5,
NOTE_D5,NOTE_D5,NOTE_D5,NOTE_D5
int harm1Durations = {
400, 400, 400, 400,
400, 400, 400, 400,
400, 400, 400, 400,
400, 400, 400, 400
digitalWrite(8, OUTPUT);
digitalWrite(9, OUTPUT);
for (int i = 0; i < notes; i++){
tone(8, melody1_, mel1Durations*);_
tone(9, harmony1_, harm1Durations);
I get these error messages:
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer0_pin_port’
libraries/ToneLibrary/Tone.cpp.o (symbol from plugin):(.text+0x0): first defined here
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer0_pin_mask’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer1_pin_port’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer1_pin_mask’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer2_pin_port’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer2_pin_mask’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer0_toggle_count’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer1_toggle_count’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of timer2_toggle_count’
Tone.cpp.o (symbol from plugin): In function timer0_pin_port':*</em></em></em> <em><em><em>*(.text+0x0): multiple definition of __vector_7’
/Users/JarettLeVanRules/Downloads/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/main.cpp: In function ‘main’:
/Users/JarettLeVanRules/Desktop/Random/Random.ino:58:40: warning: iteration 16 invokes undefined behavior [-Waggressive-loop-optimizations]
tone(9, harmony1, harm1Durations);
/Users/JarettLeVanRules/Desktop/Random/Random.ino:56:1: note: containing loop*
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno._
Only one tone can be generated at a time. If a tone is already playing on a different pin, the call to tone() will have no effect. If the tone is playing on the same pin, the call will set its frequency.
tone library
UKHeliBob:
...within some limits
