Is it possible to send data using nfc between two arduinos?
I was wondering if it was possible to send data from one arduino to another via nfc.
It would also be great if anyone knows any tutorials for this.
or if they could guide me.
Sure.
No. Not that I have seen
What sort of experience do you have with electronics? - It involves designing your own circuits and building them using at least strip board. If you have only used solderless bread board then you are not experienced enough. Do you have an oscilloscope? Because you will need one and need to know how to use it.
What sort of data do you want to pass?
Is it in both directions? - You can only pass data in one direction at a time and you will need some protocol to control the TX and RX.
