Is it possible to trigger 2 seprate bits of code with 2 seprate buttons?
I am Building a 4 legged walker with 2 servos for School and was wondering if it was possible to trigger the Walking with one button and when the button is pressed again to turn it off(note it´s a push button)
For the second button i want to do the same Thing is this possible? Btw I am new to coding so yeah...
Here is an example of how to use the state change detection to toggle an output pin (pin 13, on board LED).
// This is to illustrate using tne state change detectin method to
// toggle the state of a pin (Pin 13, the on board LED)
// a momentary switch (pushbutton) is wired from pin 8 to ground
// by C Goulding aka groundFungus
// this constant won't change:
const int  buttonPin = 8;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Variables will change:
boolean buttonState = 0;         // current state of the button
boolean lastButtonState = 0;     // previous state of the button
   // initialize the button pin as a input with internal pullup enabled
   pinMode(buttonPin, INPUT_PULLUP);
   // initialize the LED as an output:
   pinMode(ledPin, OUTPUT);
   // initialize serial communication:
   //check the button state every 50 milliseconds
   static unsigned long timer = 0;
   unsigned long interval = 50;
   if (millis() - timer >= interval)
      timer = millis();  // reset timer
      // read the pushbutton input pin:
      buttonState = digitalRead(buttonPin);
      // compare the buttonState to its previous state
      if (buttonState != lastButtonState)
         if (buttonState == LOW)
            // if the current state is LOW then the button
            // went from off to on:
            digitalWrite(ledPin, !digitalRead(ledPin)); // toggle the output
      // save the current state as the last state,
      //for next time through the loop
      lastButtonState = buttonState;
