Is it possible to upload a sketch to an ATMEGA328p pu with the usb2serial?
Hello people,
I tried to upload a sketch to an ATMEGA328p-pu (with the bootloader installed) with the USB2serial adapter, but i could not figure out how. I can select it in the arduino IDE on COM4, I installed the adapter driver, I connected the RX,TX,GND and 5V to the arduino on a breadboard but it still does not work. (it says 'programmer is not responding')
Does anyone know if it is even possible to upload a sketch like this. If yes; how?
Thanks!
Bas Peter
Hi, welcome to the forum.
I noticed that you didn't get an answer for your first question. Sorry :frowning:
With normal usb-serial adapters it is like this:
The DTR is used via 100nF to the reset. The DTR is used to reset the ATmega328P, and that starts the bootloader.
Those usb-serial adapters have pins labeled RX and TX. Sometimes connect RX-TX and TX-RX, but also try RX-RX and TX-TX.
Some usb-serial adapters have signals of 3.3V, in some cases that is not enough for an ATmega328P.
This is the Arduino USB 2 Serial : http://www.arduino.cc/en/Main/USBSerial
Some boards have pins, and this USB 2 Serial can be connected to those pins directly (without wires).
For a ATmega328P you still need the 100nF between the resets. And I think connect it with RX-TX and TX-RX.
Before using the USB 2 Serial, I would like to know if you ATmega chip is properly bootloaded and that it has a good circuit.
Did you buy a ATmega328P on Ebay with bootloader ? If so, I don't trust that bootloader.
Do you have a schematic or a photo to show how you have connected the wires to the ATmega chip ?
A 16MHz bootloader will only work with a 16MHz ATmega328P, and you need the two 22pF. And 5V and GND need to bee on both sided of the chip. Don't connect AREF to 5V. And so on....
Oh dear!
When in doubt, Gammon! :grinning:
Read it all through!
Thanks and no problem, I think I posted the question in the wrong section of the forum.
I bought two atmega328p-pu's of dealextreme without any bootloader. This because they were cheap and it is really easy to burn a bootloader to the atmega with a proper Arduino UNO.
I soldered the chip, a 1Mhz crystal, two 22pF cap's, a few resistors and some headers to a arduino protoshield and connected everything properly.
I hoped I could connect the usb2serial adapter to this to upload sketches to the Atmega.
I did actually connect AREF to 5v, I found this in the 'aruino on a breadboard' tutorial. I don't know if this could be the problem.
I bought the official arduino usb2serial adapter, so I will try the tips you gave me. I connected tx-tx and rx-rx, so that might be the problem....
Thanks a lot!
That is an error in that page. I know. Don't connect AREF to 5V.
I hope you have a 16MHz crystal, not 1MHz crystal :grin:
oh darn, stupid typo's. I used a 16Mhz crystal. :slight_smile:
Should AREF be connected to something else?
It actually worked with rx-tx, and the reset lines connected with a cap.
thanks a lot!
(i still dont really know what to do with AREF though :slight_smile: )
BasPeter:
(I still don't really know what to do with AREF though :slight_smile: )
Absolutely nothing!
(Except of course, a 0.1μF capacitor.)
Thank you Peter n for giving a good and proper answer.Providing the atmega with a seperate power supply and pressing the reset button at the correct moment while uploading helps.I was able to upload the program.
Thank You
