Is it possible to use nano I/O carriers with Nano RP2040 Connect
I'm not sure if this new board can be used with the nano shields that already exist. For example the very expensive Nano motor carrier dev board in its documentation it says it is compatible with
Nano 33 IoT
but doesn't say anything about Nano RP2040.
I would like to use Arduino RP2040 Connect in a Robotics Project. and I'm looking for carrier board such as pico has Robotics Board fo Pi Pico. The reason I choose the Arduino RP2040 Connect rather than Pico is because of their Wireless&Bluetooth and IMU sensor.
I would very much doubt it.
To be sure you would have to check the pin out of the Nano 33iot against the Nano connect RP2040 we're identical. Easy enough to do.
Hey, Thanks for the answer and sorry to be sure, what would you doubt it ? They are mostly same, Nano33IoT has 2 RESET pins and one of them (left RESET pin) is REC in Nano RP2040. What is the purpose of that REC pin ?
The REC pin ( QSPI_CSn pin 56 of RP2040) when connected to ground and Reset is pressed will open the mass storage if the board is connected via USB to a computer.
