I'm trying to make a small sensor logger using an Arduino Nano, logging to a micro SD card using SPI. I also want to use the on-board LED to indicate various things (e.g. blinking rapidly = logging data, blinking slowly = idle, etc.).
Will writing to pin 13 using digitalWrite() interfere with the functioning of the SD card logger, with which I communicate using SPI? I'd like to not have to add an external LED to this little thing I'm building.
#include <SPI.h>
int led = 13;
SPI.begin ();
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
The LED does not blink, so the answer is no, you can't use it for both purposes.
You could conceivably turn SPI off if you needed to blink the LED, and turn it back on afterwards:
#include <SPI.h>
int led = 13;
SPI.begin ();
SPI.end (); // turn SPI off for a moment
SPI.begin ();// turn SPI back on
But I would do that with a certain amount of caution, if you had open files on the SD card.
Thanks - yeah, turning SPI on and off seems clunky, and with the delays required for blinking it would probably slow the whole thing down a lot. Looks like I'm adding an LED to this thing.
