That depends on how you damage it If you put (as an extreme example) 230V on an input of the IC, it will go through your complete circuit including the NodeMcu. If you damage it in such a way that a select input tat is connected to the NodeMcu becomes a short, you can damage the NodeMcu.
As you must have gone through my case, is there any chances of short circuiting?
I don't know. If you are as clumsy as I am, there is a good chance Although I must admit that I have only blown up one ProMini in the 5 years that I'm working with Arduinos.
Then there seems no probelm in trusting you By the way I will get the multiplexer by evening then I will update you regarding the same.
Thanks @chrisknightley @6v6gt @JohnRob @sterretje and @Paul_B for your help, The multiplexer is working fine with the Nodemcu. Thanks for quick help
