Is LM293 an inverting comperator? & basic questions
Hello everyone!
I'm exploring comperators and got hold of some LM293P versions. Here is the datasheet for it so you don't have to search: https://www.ti.com/lit/ds/symlink/lm2903b.pdf
I get confused. Nowhere in the datasheet did I read if it's inverting or non-inverting. Is it's just how you use it, which input you choose to be the reference voltage?
And my second question is about comperator vs. op-amps. It seems that people use it interchangably which would suggest they do the same thing. Eg. in this article https://www.circuitstoday.com/voltage-comparator they state
Whenever Vin goes above 6V, the output swings to ~+12V DC and vice versa.
However, in the datasheet I see this diagram and it seems to me, out will never be +VCC , not without a pullup on out anyway.
So are comperators and op-amps the same? Am I missing something here?
Thanks!
You're missing the (implied) external pullup resistor. Look at the rest of the data sheet, it will make this very clear, in the application or test circuit section. See 8.2 Typical Application.
Your other question - op amps are designed for linear (analog output) operation, comparators non-linear (binary output) operation. They can sometimes be used interchangeably, but they are heavily optimized for one purpose or the other.
Only a complete circuit can be inverting or non-inverting. No op amp or comparator can be called that, it is just a differential amplifier.
Simply put:
  • If the IN+ is higher than the IN- the output is open circuit (high with a pullup)
  • If the IN+ is Lower than the IN- the output is low.
That question is simply quite meaningless. It is a comparator so it is both. It has an inverting and a non-inverting input.
Comparators generally have open-collector outputs.
Yes, exactly that.
Using Op Aps as Comparators.pdf (188.2 KB)
While one can argue a comparator may be less costly the real difference is speed.
The internals of a comparator are optimized for speed, making them much faster than opamps. Not just a little faster, much faster.
An opamp's internal circuits are optimized for linearity and gain. They are designed to be operated in a closed loop configuration (i.e. the two inputs have no voltage difference).
This is an amazingly well written document for explaning things! Thank you for the link, I think this will be my go-to guide.
