is my arduino have problem?
hello,
i have a leonardo, and i guess it has some problem on serial communucation.
i wrote a small program
pinMode(5,INPUT);
int but1=0;
but1=digitalRead(10);
Serial.println(but1);
delay(100);
when i give 5 volts to pin 10(i tried almost all pin 1,3,5,6,7,8,11), on serial print always 1 but when i take out 5 volts, on screen 1 and 0 changing randomly
, 15 second 0,
10 second 1,
2 second 0,
3 times 1...
is there any problem in my leonardo?
use Serial.println(but1, DEC); to print a decimal value...
so, i changed program like this
pinMode(5,INPUT);
int but1=0; //buton de?eri 1-0
but1=digitalRead(5);
delay(100);
still same ,
also i just realize when i give 5 volts, a little bit later, for a small duration "0" coming, than turns to 1, after little bit later again for small duration 0 coming and it happining agian and again..
What do expert to get. Digital is high or low. If don't have 5 V what connected to the pin? Is nothing connected you don't know if it is high or low.
A floating pin won't give any consistent reading.
Please use code tags.
dear carlmikael, english is not my native language, so pls use simple english :slight_smile:
i want wrote a program, when i push button led will open, and when i push again led will close, but i couldn't read the button 0 or 1...
when there is nothing connected to pin 10, screen 1 and 0 changing randomly, when i give 5v (on arduino 5v pin) to pin 10, generally on screen 1, for a small duration 0 coming than turns 1...
dear awol i just seen to code tags, thank you.
what do you mean with "floating pin".
Use the built-in pull up resistors or fit your own external pull-downs.
when there is no cable on arduino(there was a bread board with leds and button, i take out all the cable from arduino), on screen i seen 1-0 randomly, what pull up resistor will changes. i mean without anything, numbers are coming randomly, isnt this a problem?
Without anything connected, what do you expect to read?
High?
Low?
Why do you expect that?
No, it isn't a problem.
