Is my Arduino Nano 33 BLE Sense defective?
I'm using an Arduino Nano 33 BLE Sense board. On this board, D5 and D6 are not behaving correctly. I'm trying a simple test with no other hardware connected:
const int pinD5 = 5; // P1.13
const int pinD6 = 6; // P1.14
  // Configure D5 and D6 as outputs
  pinMode(pinD5, OUTPUT);
  pinMode(pinD6, OUTPUT);
  // Initialize both pins to LOW
  digitalWrite(pinD5, LOW);
  digitalWrite(pinD6, LOW);
  // Set D5 and D6 HIGH
  digitalWrite(pinD5, HIGH);
  digitalWrite(pinD6, HIGH);
  delay(1000); // Wait 1 second
  // Set D5 and D6 LOW
When I measure voltages, D6 always shows 3.3v and doesn't change. D5 fluctuates between about 1.6v and 2.1v every second.
I also tried a test with reading them as inputs. They always show a HIGH value and it never changes.
No other IO I've found so far has these issues. Just D5 and D6.
What's going on here?
If it's new, return it.
It was unopened in the box, but it's past its return date.
My suspicion is there's some manufacturing flaw, possible bad solder.
There's nothing 'special' about them that makes them function any different from the others.
Contact the vendor and inform them of your experience. As a goodwill gesture, they may offer to replace the item for you.
Hello,
Would you please contact Arduino support using the form : https://www.arduino.cc/en/contact-us/
