When i plug into any power source or to my Windows 10 pc, the 'L' and 'ON' led is always on
When i press the reset button, nothing happens with the leds
When i put a jumper on reset and ground, nothing happens until a press the reset button, Both leds go off
When i compile any sketch it works with no errors
When it uploads, I get this error
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 3,896 bytes (12%) of program storage space. Maximum is 32,256 bytes.
Global variables use 32 bytes (1%) of dynamic memory, leaving 2,016 bytes for local variables. Maximum is 2,048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
I will also upload the verbose output for compilation
Is the bootloader gone??
Is a ic damaged???
Is there anything wrong with my pc??
SPECS
*Arduino Uno R3
*CH340g Usb to seriel
*Working fine perfectly before
*windows 10 running latest ide
*Loop back test didnt work
*Atmel Mega328p
There is a bug in Arduino IDE 1.6.10 that can cause that issue when you start the IDE by opening a sketch(.ino) file(by double clicking on it, etc.). Please try this:
Close all Arduino IDE windows
Start the Arduino IDE, not by opening a sketch file.
Open the sketch file via File > Open, File > Sketchbook, or File > Examples
The last opened sketch will automatically load when you open the Arduino IDE, that one should also work fine.
Please let me know how this works for you so I can provide the developers with more evidence that this is a legitimate bug.
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jun 22 2016 at 16:05:21
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xca
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I got this problem a week ago and i searched the internet for hours looking for solutions
Well at least it solved your other problem. You've now experienced all 3 of the most common issues with Arduino IDE 1.6.10/Arduino AVR Boards 1.6.12("Cannot run program "REMOVE/bin/avrdude", "cc1.exe: error: -fno-fat-lto-objects are supported only with linker plugin.", and "An error occurred while uploading the sketch"). You must be a bug magnet! Well I have to give you points for persistence. Stick with it and you'll get there sooner or later.
