I have a r3 Arduino UNO. I was working with a 20 volt supply and am worried that I killed my board. I believe I was careful not to send the power to the wrong place, but I may have messed up. So onto the symptoms:
green led light is not turning on (not sure if it ever did, never checked)
reset led (pin 13) is solid orange
when I try to send code to the board, I receive this error:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9d
and on to all 10 tries.
I have tried to follow the troubleshooting tips I have found from this error, by I can't fix the error.
Things I have tried:
COM port is correct
baud rate is correct for my chip (I think)
board has nothing in pin 0 or 1 (or anywhere else for that matter, I removed all of my wiring)
other information:
windows 10
arduino UNO rev3
arduino IDE 1.6.8
Is there anything else I should try? Did I kill my board?
