I have a Arduino Uno board, and it doesn’t run the code for a led project. I have followed the steps in the troubleshooting guide and when the board is connected to my linux box, it returns what I type in the serial monitor .
The board is connected to /dev/ttyACM1, usb port, and when I try and re upload the code, I get this error message:
Using Port : /dev/ttyACM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
Invalid library found in /home/rob/sketchbook/libraries/ArduinoColor: /home/rob/sketchbook/libraries/ArduinoColor
Invalid library found in /home/rob/sketchbook/libraries/I2CexpDiag: /home/rob/sketchbook/libraries/I2CexpDiag
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Also the reset button does not do anything now.
Would replacing the 328p chip do any good.
