Is my code is right for Emax BLheli125 Oneshot ESC?
I am using a teensy 4.1 microcontroller with Emax BLheli125 Oneshot ESC for drones, is my code right for Emax BLheli125 Oneshot ESC? My ESCs not run expected at higher loops above 1Khz, please help me to implement the right code. thanks.
#include <Arduino.h>
class ESC
private:
    /* data */
public:
    int pin_m1;
    int pin_m2;
    int pin_m3;
    int pin_m4;
    int wentLow;
    int32_t pulseStart, timer;
    int flagM1;
    int flagM2;
    int flagM3;
    int flagM4;
    int MOTOR_IDEL_SPEED = (int)1200 / 8;
    ESC(int pinM1=3, int pinM2=4, int pinM3=5, int pinM4=6);
    void attachMototrs();
    void commandMotors(int m1_cmd, int m2_cmd, int m3_cmd, int m4_cmd);
ESC::ESC(int pinM1, int pinM2, int pinM3, int pinM4)
    this->pin_m1 = pinM1;
    this->pin_m2 = pinM2;
    this->pin_m3 = pinM3;
    this->pin_m4 = pinM4;
void ESC::attachMototrs()
    pinMode(this->pin_m1, OUTPUT);
    pinMode(this->pin_m2, OUTPUT);
    pinMode(this->pin_m3, OUTPUT);
    pinMode(this->pin_m4, OUTPUT);
void ESC::commandMotors(int M1_cmd, int M2_cmd, int M3_cmd, int M4_cmd)
    RADIO FREQUENCY ARE 1000 TO 2000 AND MOTOR RUN AT 125 TO 250 SO WE NEED TO RADIO SIGNAL TO FECTOR OF 8.
    EX. MOTOR 1 = CHANNEL 3 / 8;
    MOTOR 1 = FRONT TIGHT
    MOTOR 2 = BOTTOM RIGHT
    MOTOR 3 = BOTTOM LEFT
    MOTOR 4 = FRONT LEFT
    wentLow = 0;
    flagM1 = 0;
    flagM2 = 0;
    flagM3 = 0;
    flagM4 = 0;
    // Write all motor pins high
    digitalWrite(this->pin_m1, HIGH);
    digitalWrite(this->pin_m2, HIGH);
    digitalWrite(this->pin_m3, HIGH);
    digitalWrite(this->pin_m4, HIGH);
    pulseStart = micros();
    // Write each motor pin low as correct pulse length is reached
    while (wentLow < 4)
    { // keep going until final (4th) pulse is finished, then done
        timer = micros();
        if ((M1_cmd <= timer - pulseStart) && (flagM1 == 0))
            digitalWrite(this->pin_m1, LOW);
            wentLow = wentLow + 1;
            flagM1 = 1;
        if ((M2_cmd <= timer - pulseStart) && (flagM2 == 0))
            digitalWrite(this->pin_m2, LOW);
            flagM2 = 1;
        if ((M3_cmd <= timer - pulseStart) && (flagM3 == 0))
            digitalWrite(this->pin_m3, LOW);
            flagM3 = 1;
        if ((M4_cmd <= timer - pulseStart) && (flagM4 == 0))
            digitalWrite(this->pin_m4, LOW);
            flagM4 = 1;
I think you forgot that you posted the same question 2 hours earlier.
Now I am getting worried, if someone answers your questions, you will have forgotten that in two hours :slight_smile:
Lol, I am not forgotten the answer, brother, can you help me, please?
