Is my code layout correct?
// Proyek Sensor Parkir PJBL Kelompok Abbyan
// Library yang diperlukan
#include <Wire.h>
#include <NewPing.h>
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
// Pengenalan Pin dan Jarak
#define TRIGGER 3
#define ECHO 4
#define MAXDISTANCE 250
// Inisialisasi Objek
DFRobotDFPlayerMini myDFPlayer;
LiquidCrystal_I2C lcd(0x27, 16, 2);
SoftwareSerial mySoftwareSerial(10, 11);
NewPing sonar(TRIGGER, ECHO, MAXDISTANCE);
// Definisi Pin
const int Red = 5;
const int Yellow = 6;
const int Green = 7;
const int Buzzer = 8;
// Variabel Jarak
int jarak = 0;
int distance;
// Variabel dan Konstanta Pengaturan Buzzer
int BuzzerState = LOW;
const long interval = 200;
const long interval2 = 400;
const long interval3 = 800;
const long interval4 = 2000;
unsigned long previousMillis = 0;
// Setup
mySoftwareSerial.begin(9600);
if (!myDFPlayer.begin(mySoftwareSerial)) {
lcd.begin(16, 2);
pinMode(Red, OUTPUT);
pinMode(Yellow, OUTPUT);
pinMode(Green, OUTPUT);
pinMode(Buzzer, OUTPUT);
// Loop Utama
distance = sonar.ping_cm();
jarak = distance;
if (jarak <= 0) {
jarak = 0;
LCDkosong();
buzzerAman();
stopWarning();
} else if (jarak >= 1 && jarak <= 5) {
LCDnabrak();
VbuzzerNabrak();
stopWarningNabrak();
} else if (jarak >= 6 && jarak <= 12) {
LCDawas();
buzzerTipis();
VbuzzerAwas();
stopWarningAwas();
} else if (jarak >= 13 && jarak <= 22) {
LCDpelan();
buzzerDekat();
VbuzzerPelan();
stopWarningPelan();
} else if (jarak >= 23 && jarak <= 50) {
LCDaman();
buzzerJauh();
VbuzzerAman();
stopWarningAman();
delay(50);
updateLCDStatus();
// Fungsi Pembaruan Status LCD
void updateLCDStatus() {
lcd.setCursor(0, 0);
lcd.print("Jarak : ");
lcd.print(sonar.ping_cm());
lcd.print(" cm ");
lcd.setCursor(0, 1);
lcd.print("Status : ");
// Fungsi Status LCD Kosong
void LCDkosong() {
lcd.setCursor(9, 1);
lcd.print("KOSONG! ");
// Fungsi Status LCD Nabrak
void LCDnabrak() {
lcd.print("NABRAK! ");
// Fungsi Status LCD Awas
void LCDawas() {
lcd.print("AWAS! ");
// Fungsi Status LCD Pelan
void LCDpelan() {
lcd.print("PELAN! ");
// Fungsi Status LCD Aman
void LCDaman() {
lcd.print("AMAN! ");
// Fungsi Peringatan Kosong
void stopWarning() {
digitalWrite(Buzzer, LOW);
digitalWrite(Red, LOW);
digitalWrite(Yellow, LOW);
digitalWrite(Green, LOW);
// Fungsi Peringatan Nabrak
void stopWarningNabrak() {
digitalWrite(Buzzer, HIGH);
digitalWrite(Red, HIGH);
digitalWrite(Yellow, HIGH);
digitalWrite(Green, HIGH);
// Fungsi Peringatan Awas
void stopWarningAwas() {
// Fungsi Peringatan Pelan
void stopWarningPelan() {
// Fungsi Peringatan Aman
void stopWarningAman() {
// Fungsi Peringatan Suara Nabrak
void VbuzzerNabrak() {
myDFPlayer.volume(30);
myDFPlayer.play(1);
// Fungsi Peringatan Suara Awas
void VbuzzerAwas() {
myDFPlayer.play(2);
// Fungsi Peringatan Suara Pelan
void VbuzzerPelan() {
myDFPlayer.play(3);
// Fungsi Peringatan Suara Aman
void VbuzzerAman() {
myDFPlayer.play(4);
// Fungsi Buzzer Tipis
void buzzerTipis() {
if (currentMillis - previousMillis >= interval){
if (BuzzerState == LOW) {
BuzzerState = HIGH;
BuzzerState = LOW;
digitalWrite(Buzzer, BuzzerState);
// Fungsi Buzzer Dekat
void buzzerDekat() {
if (currentMillis - previousMillis >= interval2){
BuzzerState = HIGH;
BuzzerState = LOW;
// Fungsi Buzzer Jauh
void buzzerJauh() {
if (currentMillis - previousMillis >= interval3){
BuzzerState = HIGH;
BuzzerState = LOW;
// Fungsi Buzzer Aman
void buzzerAman() {
if (currentMillis - previousMillis >= interval4){
BuzzerState = HIGH;
BuzzerState = LOW;
// Terimakasih Banyak!
To get the best support, apart from reading the forum guidelines for posting….
In the IDE, press CTRL+T to auto format the code, then copy and paste all the code into ‘CODE TAGS’ so it retains the formatting, and is easy for helpers to use in their own systems for assistance,
Generally, it looks ok, but you don’t need the ‘empty’ // comment lines - they just add scrolling through long blocks of code.
Have you compiled it yet ? Any errors ?
Which Arduino are you using? What and how are your other devices connected ?
This verifies something happened, but does nothing.
I guess it would help most of us if your comments were also in English? please?
The loop code looks like a good fit for a switch-case structure.
https://forum.arduino.cc/t/beginners-using-the-switch-case-statement/680177/9
this can be done just once at the top of loop() with currentMillis made global
these routines: buzzerTipis (), buzzerDekat (), buzzerJauh () and buzzerAman () could all be replaced by a single function with the interval as an argument. same for other functions (e.g. VbusserAwas()) where some variable can be passed as an argument
#include <Wire.h>
#define TRIGGER 3
#define ECHO 4
// Definisi Pin
const int Red = 5;
// Variabel Jarak
int jarak = 0;
int distance;
// Setup
lcd.begin(16, 2);
// Loop Utama
jarak = distance;
if (jarak <= 0) {
jarak = 0;
LCDkosong();
buzzerAman();
stopWarning();
LCDnabrak();
VbuzzerNabrak();
LCDawas();
buzzerTipis();
VbuzzerAwas();
stopWarningAwas();
LCDpelan();
buzzerDekat();
VbuzzerPelan();
stopWarningPelan();
LCDaman();
buzzerJauh();
VbuzzerAman();
stopWarningAman();
delay(50);
updateLCDStatus();
lcd.print(" cm ");
void LCDkosong() {
void LCDnabrak() {
void LCDawas() {
void LCDpelan() {
void LCDaman() {
myDFPlayer.play(1);
myDFPlayer.play(2);
myDFPlayer.play(3);
myDFPlayer.play(4);
BuzzerState = HIGH;
BuzzerState = LOW;
BuzzerState = HIGH;
BuzzerState = LOW;
void buzzerJauh() {
BuzzerState = HIGH;
BuzzerState = LOW;
void buzzerAman() {
BuzzerState = HIGH;
BuzzerState = LOW;
Here is the code in code tags.’
Can’t format it now…..
No IDE on mobile.
I might translate it later.
I mostly understand the comments.
// Car Parking sensor project?
// Libraries.
#include <Wire.h>
// define pin numbers and distance
#define TRIGGER 3
#define ECHO 4
// initialize objects.
// Define pins.
const int Red = 5;
// Variables for distance
int jarak = 0; // jarak means distance....
int distance;
// Variables and contants for buzzer
// Setup
  lcd.begin(16, 2);
// Main Loop
  jarak = distance; // oh.....
  if (jarak <= 0) {
    jarak = 0;
    LCDkosong();
    buzzerAman();
    stopWarning();
    LCDnabrak();
    VbuzzerNabrak();
    LCDawas();
    buzzerTipis();
    VbuzzerAwas();
    stopWarningAwas();
    LCDpelan();
    buzzerDekat();
    VbuzzerPelan();
    stopWarningPelan();
    LCDaman();
    buzzerJauh();
    VbuzzerAman();
    stopWarningAman();
  delay(50);
  updateLCDStatus();
// Function for updated the  Status of the LCD
  lcd.print("Jarak : "); // jarak means distance
  lcd.print(" cm ");
// Function for when there is no car detected? Prints "empty" to LCD
void LCDkosong() {
  lcd.print("KOSONG! ");// kosong means empty.
// Function for when a object is detected? Prints "crash" to LCD
void LCDnabrak() {
  lcd.print("NABRAK! ");//Nabrak means crash?
// Function for Warning? When it is too close? Prints "warning!" to LCD
void LCDawas() {
  lcd.print("AWAS! "); // awas means warning.
// Function for Slow? Prints "Slow!" to LCD
void LCDpelan() {
  lcd.print("PELAN! ");// pelan means slow
//Function for Safe distance?
void LCDaman() {
  lcd.print("AMAN! ");// aman means safe
// Fungsi Peringatan Kosong (Maybe no car warning function? )
// Crash warning?
// Safe function? Turns green on......
// Crash sound.
  myDFPlayer.play(1);
// Warning sound.
  myDFPlayer.play(2);
// Slow sound.
  myDFPlayer.play(3);
// Safe sound.
  myDFPlayer.play(4);
// Fungsi Buzzer Tipis(Unclear what this means.....)
  if (currentMillis - previousMillis >= interval) {
      BuzzerState = HIGH;
      BuzzerState = LOW;
// Function when near, do something with buzzer.
  if (currentMillis - previousMillis >= interval2) {
      BuzzerState = HIGH;
      BuzzerState = LOW;
// Function for when far, do something with buzzer.
void buzzerJauh() {
  if (currentMillis - previousMillis >= interval3) {
      BuzzerState = HIGH;
      BuzzerState = LOW;
// Function for when safe, do something with buzzer. Um....THis code is really similar.
void buzzerAman() {
  if (currentMillis - previousMillis >= interval4) {
      BuzzerState = HIGH;
      BuzzerState = LOW;
// Thank you a lot!
I have translated the comments(not with a translate service…..)
Thanks for taking the trouble. Now readable, even though my only comment to the OP is that I like the section headings. Wish my sketches looked as well organised.
P.S: As I have a Nano and DFR player at hand I'd like to have tried the four distance-related tracks and also hear from the OP how the project is performing.
