I have 2 SD card module.
catalex Sd card module. first time i buy the first sd card, only 5 initialize the datalogging would work.
After that, it wont work. Then i buy the second sd card module. this time, only 4 time initialize will work, more than that, it wont work. I'm making a Library book returner project consist Servo,ds3231,Lcd with i2c, and arduino mega.
i also tried CardInfo.
this is result what i get:
Initializing SD card...initialization failed. Things to check:
- is a card inserted?
- is your wiring correct?
- did you change the chipSelect pin to match your shield or module?
is my sd card broken/damaged??
if you need my code, just tell in the comment section.
Please help me...
